title: Charmhub | Tempo HA docs - How to enable correlation from traces to metrics
description: Grafana supports a trace-to-metrics correlation feature that lets you
  navigate from a span in a trace view to metrics relevant for that span to make...
url: https://charmhub.io/topics/charmed-tempo-ha/enable correlation from traces to
  metrics
# Tempo HA docs - How to enable correlation from traces to metrics
Grafana supports a trace-to-metrics correlation feature that lets you navigate from a span in a trace view to metrics relevant for that span to make troubleshooting issues easier.
See more: [Grafana trace-to-metrics](https://grafana.com/docs/grafana/latest/explore/trace-integration/#trace-to-metrics)
> In Grafana, traces are linked to metrics by running a custom query that uses tags from the span. We use the `juju_topology` tags that are added to both spans and metrics. This lets us do a simple “get all metrics” query using those tags to grab all the metrics coming from the same service that created the span, during the same time window.
See more: [Juju topology](https://discourse.charmhub.io/t/juju-topology-labels/8874)
To leverage this feature, we’ll need [charmed Tempo HA](https://charmhub.io/tempo-coordinator-k8s) and [charmed Mimir](https://charmhub.io/mimir-coordinator-k8s) to store traces and metrics, and [charmed Grafana](https://charmhub.io/grafana-k8s) to run the dashboard where we can view and explore them.
## [Production Setup](https://charmhub.io/topics/charmed-tempo-ha/enable correlation from traces to metrics#p-39723-production-setup)
The plan is for COS to come with this feature enabled by default.
See more: [Deploy COS using terraform](https://documentation.ubuntu.com/observability/latest/tutorial/installation/cos-canonical-k8s-sandbox/)
When you deploy COS using its latest terraform module, you’ll automatically get all the required integrations needed to enable trace-to-metrics correlation.
## [Development Setup](https://charmhub.io/topics/charmed-tempo-ha/enable correlation from traces to metrics#p-39723-development-setup)
For testing purposes, instead of deploying the entire stack, you can use the commands below to deploy a lighter setup. This minimal deployment includes only the required charms and integrations needed to enable and try out the trace-to-metrics feature.
# deploy a testing tempo cluster
juju deploy tempo-coordinator-k8s tempo --trust  --channel 2/edge
juju deploy tempo-worker-k8s tempo-worker --channel 2/edge --trust
juju deploy seaweedfs-k8s tempo-fs --channel latest/edge
juju integrate tempo tempo-fs
juju integrate tempo tempo-worker
# deploy a testing mimir cluster
juju deploy mimir-coordinator-k8s mimir --trust  --channel 2/edge
juju deploy mimir-worker-k8s mimir-worker --channel 2/edge --trust
juju deploy seaweedfs-k8s mimir-fs --channel latest/edge
juju integrate mimir mimir-fs
juju integrate mimir mimir-worker
# deploy grafana
juju deploy grafana-k8s grafana --trust --channel 2/edge
# integrations
juju integrate mimir:grafana-source grafana
juju integrate tempo:grafana-source grafana
juju integrate tempo:receive-datasource mimir
The crucial integration to enable this telemetry correlation feature is the one between Tempo and Mimir, allowing them to exchange the datasource UIDs needed by grafana to know which custom custom queries to run to fetch metrics for a given trace.
See more: [`grafana_datasource_exchange`](https://charmhub.io/topics/charmed-tempo-ha/correlating-traces)
## [Deploy a charmed workload to observe the correlation](https://charmhub.io/topics/charmed-tempo-ha/enable correlation from traces to metrics#p-39723-deploy-a-charmed-workload-to-observe-the-correlation)
For this example, we’ll be using [charmed Pyroscope](https://charmhub.io/pyroscope-coordinator-k8s) to observe the correlation between its traces and metrics, but you can deploy any charmed workload that:
1. Provides its workload metrics over the [prometheus\_scrape](https://charmhub.io/integrations/prometheus_scrape) interface or the [prometheus\_remote\_write](https://charmhub.io/integrations/prometheus_remote_write) interface.
2. Provides its *workload* traces over the [tracing](https://charmhub.io/integrations/tracing) interface.
# deploy a testing pyroscope cluster
juju deploy pyroscope-coordinator-k8s pyroscope --trust  --channel 2/edge
juju deploy pyroscope-worker-k8s pyroscope-worker --channel 2/edge --trust
juju deploy seaweedfs-k8s pyroscope-fs --channel latest/edge
juju integrate pyroscope pyroscope-fs
juju integrate pyroscope pyroscope-worker
# deploy an otel collector that will scrape metrics
juju deploy opentelemetry-collector-k8s otelcol --trust --channel 2/edge
juju integrate otelcol:send-remote-write mimir
juju integrate pyroscope:metrics-endpoint otelcol
juju integrate pyroscope:workload-tracing tempo
## [Explore the telemetry data in the Grafana UI](https://charmhub.io/topics/charmed-tempo-ha/enable correlation from traces to metrics#p-39723-explore-the-telemetry-data-in-the-grafana-ui)
Open the Grafana web UI from your local web browser and login using the [admin password](https://juju.is/docs/sdk/observe-your-charm-with-cos-lite#heading--log-in-to-grafana).
Then, go to `Toggle Menu` → `Explore` → select your Tempo datasource → Add filters to view traces from your charmed workload → `Run query`
When you expand any trace, each span will now have a link to `All metrics` that will fetch all metrics relevant to that span, as shown in the figure below.
Clicking that link will run the metrics query in a split panel, as shown below.
*Last updated 1 year, 1 month ago.*
[Help improve this document in the forum](https://discourse.charmhub.io/t/tempo-ha-docs-how-to-enable-correlation-from-traces-to-metrics/19094).
